Viewing 5 reply threads
    • #463
      I was experimenting with shutter speed to capture flowing water. While I was initially shooting at a low shutter speed to blur the flow, I decided for close ups I needed to stop motion and get to more abstract in a different way.
      It is very handy to have a water resistant camera.
      Available light, 120mm, 1/2000 sec. f3.4 ISO 320
      http://www.macdonough.net/Landscapes/Falls-at-Cornell/17532833_KWJmcV#P-1-10
    • #40655
      TerryDFay
      Having to focus on flowing water photography techniques brings the benefits of shutter speed to blur motion or freeze motion for more detailed shots.
      • This reply was modified 1 year, 10 months ago by TerryDFay.
    • #41378
      davisjame
      Beautiful capture! The high shutter speed really freezes the motion of the water, creating a stunning abstract effect. Great job!
      • This reply was modified 1 year, 9 months ago by davisjame.
      • #46077
        uditdevsen
        Amazing shot! I love how clearly the details are captured the timing is perfect and the composition makes it really stand out. Well done!
    • #45353
      Owenpaully
      Are you having trouble solving the New York Times Strands puzzles? Strands Hint provides essential hints and solutions.
      • This reply was modified 1 year, 3 months ago by Owenpaully.
    • #48216
      Lilyhunter
      I like how this kind of test reveals tiny issues that are hard to see with the naked eye. I once had to troubleshoot a home filter system where different taps had wildly different flow rates, so I ended up timing a bucket fill like some DIY Slice Master of plumbing diagnostics.
    • #50365
      RichardSnow
      This is most likely the beginning of a clog. I had this happen—at first, the water just drained slowly, and after a couple of weeks, it stopped draining altogether. Hair and soap scum are usually the cause. You can refer to https://bens.plumbing/blog/why-your-bathroom-sink-is-draining-slowly-and-what-to-do-about-it/ . You can also use a drain snake or a drain cleaner. In most cases, the problem is in this section of the pipe.
