Discussion Forum Leica Q Leica Q (Typ 116) UPDATE LEICA Q TO FIRMWARE 3.0
  • #24194
    GillRios
    Hi…AEL – should have the option to use it as a toggle instead of having to press it all the time. That’s how it works on most cameras anyway and for a camera that is not exactly the easiest or most ergonomic in terms of actual handling, it would make a hell of a difference. Digital cropping – instead of having the lines to show the frame limits for 35, 50 and especially 75, the image should be magnified to fill the frame. Again, that is how it works on most cameras and for a reason. When you crop to the max, you have almost no clue as to what you actually shoot. It is MUCH easier to compose without having to see the lines.
