• #38588
    katewilson
    What has been your experience with taking a taxi from FRA? How easy is it to find a taxi upon arrival, and are there any reputable taxi companies you would recommend? What are the typical fares to the city center? Any advice is appreciated!
  • #38599
    jamescrook
    Frankfurt airport, commonly known as FRA has been a fairly easy place for me in terms of getting a taxi. Arriving to a destination, selecting a taxi is quite an unproblematic process. The taxi stands are located right outside both Terminal 1 and Terminal 2. Some of these stands are very conspicuous; you cannot miss them; there are labels that guide you to these stands. Regarding reliable taxi services, you can use such companies as AtoB Transfer. This airport transfer service is safe and professional, and the car can be pre-arranged to avoid inconveniences. You can check out their services at https://atobtransfer.com/germany/frankfurt-airport-transfers/ . The costs to get from and to Frankfurt airport to central Frankfurt generally cost anything in between €25 up to €35 with regards to the traffic situation and depending on the precise location. The trip generally lasts for approximately 20 to 30 minutes.
  • #38600
    natalie183
    If you prefer to drive yourself, there are several car rental agencies located at the airport. Renting a car can be a good option if you plan to explore the surrounding areas or need more flexibility in your travel. Also, Apps like Uber and Lyft operate in Frankfurt and can provide a convenient way to travel from the airport to the city center. Prices and availability can vary, so checking the app for an estimate before you arrive is a good idea.
  • #40661
    ImboSan
    Hi. There are many ways to get around the city: from public transport to traditional taxis, but all this cannot satisfy the rapidly growing needs of modern people! In order to quickly get to the necessary place without any problems, many people use Lyft services, as it is convenient. The advantages of using Lyft are written about here https://lyft.pissedconsumer.com/customer-service.html and it will become obvious why their services are popular, and perhaps someone will become their regular customer.
  • #41634
    neilted
    Taxis are easy to find at Frankfurt Airport (FRA) with stands outside all terminals. Fares to the city center are typically €30–€40. Most taxis are reliable, with reputable companies like Taxi Frankfurt, Main Taxi, and services such as https://jewelcars.co.uk. Payment by card is often accepted, but having cash is recommended.
