- July 17, 2013 at 8:21 am #4064DougFrequent MemberCentral WashingtonJoin Date: Jul 2011Posts: 123Currently using:
Leica M, Leica S, Leica QOfflineWelcome, Terence! Nice kit… I still have and use an M2 I bought in 1967. And the 90 Tele-Elmarit I bought the next year. I don’t have your 135 or 50, but just a couple years ago picked up the same “goggled” 35 Summaron, which is “Summicron-good” IMO. Your lenses should work fine on the M8.
But as you mention IR filters, there’s that chain of consequences arising from the use of the M8 due to its IR sensitivity. I tried to ignore it and finally gave in. The next step is adopting the IR filters, which causes faintly cyan corners, which the camera can eliminate if it “knows” more about the lens… the next step being coding for that purpose (which also puts some useful info in the EXIF).
Once I accepted and dealt with all that, the M8 has been a delight to use. I had DAG code the lenses I intended to use, and while he had them, also check and adjust the focus to spec. Some were off… and digital is pickier about that than film. DAG could get that filter off too, and make sure all is well with the lens.
Good shooting!
