Discussion Forum General Discussion General Leica Discussion Losing hair, and my scalp feels sensitive, itchy, tingly almost. The Doctor pres
  • #34516
    KeeganBaldwin
    The use of Dermovate and its frequency can indeed vary depending on the context, so it’s wise to follow your doctor’s recommendations. If it’s still feeling itchy, you might want to revisit the dosage with your healthcare provider.
    As for the trichologist’s feedback, it sounds like they suspect seborrhoeic dermatitis, which can be related to itchiness and redness. It’s quite common, and while they can’t diagnose without seeing your scalp, it’s good they’re considering possibilities.
    If you’re worried about overusing Dermovate, discussing your concerns with your doctor is essential. They can provide you with a more personalized plan based on your specific situation.
    Lastly, regarding the sensitivity, you might want to explore natural remedies like Neem oil for skin. It has been known to help with skin conditions, so it could be worth giving it a try.
    Remember, you’re not alone in this, and it’s okay to seek professional advice and explore different options to address your concerns.
  • #35228
    vixec41482
    I understand what you’re going through must be challenging. Hair loss can be distressing, and the uncertainty around the right treatment can add to the stress. It’s quite common for the mind to fixate on the issue, which might make your scalp feel more sensitive. Overall, special deals from the Ulike and Ulike’s Laser Hair Removal system stands out as a reliable and innovative solution, offering a blend of advanced technology and user-centric design that caters to the needs of individuals looking for efficient, nearly painless, and enduring hair removal results.
    • This reply was modified 1 year, 4 months ago by  vixec41482.
  • #36377
    Johnydeep
    This is a very common problem faced by many women and men. Fortunately, I have not encountered this, but it would be interesting to learn about some methods that would help prevent this.
  • #36380
    Melisa Middel
    Today, many people really suffer from hair loss. I was one of them, but I suspected this problem in time. I found an article related to hair loss on the Hair Care website. With the help of their methods, I was able to combat this problem at home without any decorative means. Therefore, today my hair is shiny and healthy.
  • #43832
    neilted
    It sounds like your scalp sensitivity could be due to seborrheic dermatitis, as suggested by your trichologist. The itching and redness are common in both this condition and male pattern hair loss. Dermovate can help, but overuse can thin the skin, so it’s good that you’re being cautious. If you’re considering a hair transplant turkey for a more permanent solution, it might be a good idea to address the scalp irritation first. Since your doctor didn’t physically assess your scalp, it might be worth seeing a dermatologist to get a clear diagnosis. Stress can also worsen scalp sensitivity, so managing that might help. If symptoms persist, I’d recommend following up with a professional for tailored advice and treatment.
