- May 12, 2012 at 5:08 pm #2363
Josh Lehrer;2083 wrote: Notice the slightly flared-out focusing scale …
Not the focusing scale is flared out but the depth-of-field scale. The difference, so I’ve been told, is purely mechanical. In the original version, you could block the focusing mechanism just by pressing the rear part of the barrel (where the DOF scale is) real hard with your fingers. With the reinforced, thicker rear barrel of the new version, this cannot happen anymore. That’s all. The glass is the same in both. In normal use, no-one would squeeze the rear barrel while focusing so the original version usually is perfectly fine for everyday use. Still, you can always send the original version in to Leica to have it updated to the current version at little or no cost. But maybe you shouldn’t as it may become a sought-after collectible in the future due to its rarity.
