- October 19, 2024 at 2:03 am #39875
You’re right to be cautious when it comes to using scripts in League of Legends. It can definitely be risky, but if you use reliable scripts and take a few safety precautions, it’s much safer. First, I recommend using well-established platforms like league of legends scripts. These scripts are regularly updated to avoid detection, which significantly reduces the risk of getting banned.
To start, you should always use an updated version of the script. Outdated scripts are more likely to be detected by Riot’s anti-cheat system. Also, avoid using obvious cheats like auto-dodging every skill shot, which could easily raise suspicion. Another tip is to avoid using scripts in ranked games right away—test them out in normal or practice games first to see how they work and how comfortable you feel with them. Lastly, always be on the lookout for updates from the script provider, since they’re constantly tweaking the code to keep it undetectable. By following these steps, you should be able to enjoy the benefits of scripts while minimizing the risk.
- October 19, 2024 at 2:04 am #39876
I agree with DarthV, and I’d also add that it’s important to know what kind of scripts you’re using and how they affect your gameplay. Starting with safer options like last-hit or ward scripts can help you get a feel for them without drawing too much attention. It’s all about moderation and knowing when to use them.
