- April 4, 2025 at 5:59 pm #43654
Kaspa is a decentralized, open source, and scalable cryptocurrency that implements the GHOSTDAG protocol, which is a generalization of the Nakamoto consensus. Unlike traditional blockchains, Kaspa crypto uses a blockDAG (directed acyclic block graph), which allows blocks to be created in parallel. This significantly increases the transaction speed and network bandwidth. One of the key advantages of Kaspa is its high transaction confirmation speed, which makes it attractive for use in micropayments and other scenarios that require fast processing. The GHOSTDAG consensus algorithm allows the network to process multiple blocks per second while maintaining a high level of security.
