- August 5, 2019 at 7:14 am #22975
So I am pretty sure that most of you here won’t be interested in this mini guide because you probably already have a Leica. But for those in the process of buying an M9 or (i believe) M9-P, I’ve just been through the same process and I discovered two ways to check if the sensor was replaced or not, they should not exclude each other.
I am writing this because I really wished I knew before buying, it would have saved me a long argument with the owner that apparently did not like the fact that I did not trust him. However, seems like I’ve got the right deal.
So a short introduction: there had been 3 recall campaingns for that sensor:
Campaign 1 –> substitute with the same sensor
Campaign 2 –> substitute with a new iteration of the old sensor (that still corroded)
- November 7, 2019 at 9:23 am #23609
I’m sorry I see that you’ve explained that there were two different campaigns to solve the corrosion issues. Was that all you were trying to say? You made it sound like you had a helpful guide to detecting if a sensor has been replaced. Maybe I’m missing something?
