Discussion Forum General Discussion General Leica Discussion How to Replace Toner in Brother Printer?
  • #27929
    connectmyprinter
    Once the toner cartridge is empty, the printer will display a “replace toner ’message and you won’t be able to print further till the ink cartridge is replaced. In order to do so, you must be wondering; how to replace toner in Brother Printer? Ensure that your printer is turned on. Open up the front cover of the machine. There are two slots, drum unit and toner cartridge assembly. Now, slowly push down the green lock lever and take the toner cartridge out of the Drum unit. Put the new toner cartridge in to the drum unit after shaking it. If the installation was successful, the green lever would fit automatically.
  • #27930
    Sjackson3289
    I found your post using more education This is a very well-written article. I’ll be sure to bookmark it and come back to read more of your useful information and ideas.
