Discussion Forum General Discussion General Leica Discussion How to choose the right shampoo for eyelash extensions?
  • #32248
    Zigmund
    As far as I know, things like shampoo for eyelash extensions are best purchased in specialized online stores. Moreover, you have your own beauty salon, then you will need not only shampoo for eyelash extension A and much more for this procedure.
  • #32252
    Neolina
    As far as I know, such a procedure as eyelash extensions requires an individual approach to each client. You must have in your salon everything you need to build eyelashes, and there should be a large selection of shampoos for eyelash extensions and other materials necessary for this procedure should be in the presence in a large assortment.
  • #32253
    Zigmund
    A familiar cosmetologist says that eyelashes can break not only from which lash extension shampoo to use. This can be individually, for example, if you naturally have brittle eyelashes. And to purchase lash extension shampoo is better in online stores where they sell everything they need for this procedure. And it will be better if you have a large selection of such shampoo in the cabin, and other materials for building should be widely represented.
  • #32269
    Samuel
    Absolutely right. You have to take an individual approach in this business. The client may have allergies or some other intolerance to cosmetic products. Therefore, the choice should be huge in the salon. Just in case, consult doctors what are the cases and what should be avoided and how. Then you can store around for products.
  • #42974
    Nivelano
    It’s definitely tricky finding the right lash shampoo. Everyone’s saying individual approach is key, and they’re spot on. Allergies are real! Speaking of finding the best solutions, it reminds me of searching for the best il makiage phone number on their website – I wanted to make sure I´m getting the real deal. It’s worth checking ingredient lists super carefully because brittle lashes might need something extra gentle!
  • #43133
    Maya44
    Oil-free & sulfate-free formulas would work best for eyelash extensions. By the way, you can also make shampoo for this purpose at home. It is not much difficult.
