Discussion Forum General Discussion General Leica Discussion How can I connect my iPad to HP Printer?
- December 16, 2021 at 7:00 am #27818
The users do witness a lot of technical issues when they try to connect & print HP Printer to iPad. However, to connect the iPad to HP Printer, you are just supposed to open your mobile device, and then open the wifi network menu, and then choose your printer with direct in the name. Now, if prompted, you can enter the wifi password and then click on the join item that you wish to print, and then you can simply select the option to print. You can simply select AirPrint if prompted. BY following the steps, you can simply find out the ways to fix it.
