- September 15, 2014 at 7:49 pm #7283
If the T is the same as the M the file is loaded on a SD card and the card is inserted in the camera. The file will not open on your computer.
- September 17, 2014 at 4:26 pm #8714Kirsten VignesLegendary Member
Miami, FLJoin Date: Aug 2014Posts: 12Currently using:
Leica M, Leica CL, Leica QOffline
Naper is correct. You downloaded a ZIP file from Leica’s website, which you then extracted the .TUF file from. The file isn’t readable by a computer. You simply transfer it to you camera’s SD card and then put it into the T. I put together a step-by-step visual guide on how to update the firmware on the T since it’s not very straight forward. If you have anymore trouble, just let me know!
http://www.reddotforum.com/content/2014/09/how-to-update-the-firmware-on-the-leica-t/
- September 17, 2014 at 6:51 pm #8844Jack MacDEstablished Member
Yes, I updated fine thanks.
The instructions say double click the zip file, but apparently that was not necessary to do, as the computer automatically behind the scenes, opened to the final file.Jack - September 19, 2014 at 9:38 pm #9764dalethornEstablished Member
Leica QOffline
The T firmware update was somewhat scary. I followed the instructions down to ‘Restart the camera’, which didn’t say how to restart the camera, and that’s especially significant given the prior warnings to NOT TURN OFF the camera. So I took the big chance to turn it off after the restart screen appeared, and watched it turn on, and being the patient sort, I waited to see if something else would happen. And wouldn’t you know it, it started doing a lens update (18-56), which wasn’t described anywhere that I saw.
Leica X2 Paul Smith edition, Leica X-E, Panasonic ZS-100.
