- November 29, 2011 at 2:13 am #1611
I used the Upstrap with my Leica M8 and really liked it. However, I have not used the larger version for larger cameras so I can’t help you much there. Sorry.
- November 29, 2011 at 6:08 am #1613
I heard a lot of good things about the Upstrap as well. I am currently using the Sniper-Strap for my S2 if using a strap at all.
- November 29, 2011 at 4:06 pm #1618
Upstrap looks nice alright but I love my Domke better for a couple reasons;
– Upstrap too long. Face it, the S2 with any lens is quite a bit of mass, once it gets swinging on a long strap that’s quite a bit of inertia to control, and can swing into something very expensively. Domke seems just about right to pull up for action easily, but still not swing too far.
– the twin rubber strips on the underside will grip just about any garment. One of my problems is that in the cold weather I wear a few jackets that seem to shed most straps far too easily. The Domke rubber seems to grip just about everything
-when you use the quick disconnect on the Domke the two ends can be latched together to make a nice short carry handle/ wrist strap and you don’t have the two loose ends, which just bugs me due to the rather sloppy look on a tripod
whatever…
- November 29, 2011 at 8:53 pm #1623
I use a Tamrac Boomerang for the S2 the same as fir the D3x. Comfortable and strain-free at the back. Like Queen Elizabeth 1st and her bath, I replace the strap once per year whether it needs it or not
- November 29, 2011 at 8:57 pm #1624
I have used black Tamrac N-45’s for my larger/heavier cameras for years. They are durable and have a soft foam shoulder pad covered in suede. The foam keeps them soft, the suede keeps them from slipping. They are fully adjustable and have quick release latches to take the strap off when you are working on a tripod. Mine are both going on seven or eight years of frequent use with heavy cameras, and they are both working perfectly. They are also cheap. http://www.amazon.com/Tamrac-Leather-Padded-QuickRelease-Camera/dp/B00009VQJZ
- November 29, 2011 at 11:48 pm #1626
i used the http://www.blackrapid.com/product/camera-strap/rs-7/ black rapid strap
- November 30, 2011 at 3:52 am #1629
hikemate;1445 wrote: i used the http://www.blackrapid.com/product/camera-strap/rs-7/ black rapid strap
just saw this tonight
my next strap for sure!
- December 8, 2011 at 3:47 pm #1675Jack MacDEstablished Member
This is a reply for Marc from “Re: Advice need from wedding shooter” copied to this thread on camera straps so it can be found by others reading about straps.
Marc,
Thanks for the advice on the hand strap from http://camdapter.com
and pointing me to the correct plate for RRS.
and mentioning fun colors for the leather. I got the red which is indeed fun.
The S2 is hardly a stealth camera so I don’t mind a hand strop that stands out.I use a hand strap for my M but didn’t want to add the vertical grip to an S just to get a hand strap. Your solution that you explained on “Re: Advice need from wedding shooter”
was the answer. I also prefer hanging the camera vertically from the main strap rather than horizontal. Total upgrade cost a mere $75.
I can now walk and shoot single handed with security, and keep the shoulder strap out of the way, except when I an “storing” the camera on my shoulder or changing lenses.
JackJack
