Discussion Forum Leica S System S2 Depth of field on Summarit lenses
  • #3999
    stephan
    you can search the net for DOF calculators that take in account the sensor size and make the calculation for each lens. Unfortunately, the S-sensor is rarely covered, so this search is not easy. There are more calculators – apps, so probably the search there will be more easy (still keep in mind that you need a calculator that covers the S-sensor or something similar (like Hasselblad 39 or so)
    update:
    I found a calculator, you can choose the Pentax 645D which has roughly the sensor size of the S2 http://www.dofmaster.com/dofjs.html
    It is one of the main advantages of the S-system to get a small DOF when the lens quality is at it’s optimum (at 5,6) and that even wide open they are much better than what you can get from any 35mm lens.
  • #4002
    rootbeer
    Thank you Stephan, really appreciate your help!
    Jim
    stephan;4692 wrote: you can search the net for DOF calculators that take in account the sensor size and make the calculation for each lens. Unfortunately, the S-sensor is rarely covered, so this search is not easy. There are more calculators – apps, so probably the search there will be more easy (still keep in mind that you need a calculator that covers the S-sensor or something similar (like Hasselblad 39 or so)
    update:
  • #4003
    billhart
    https://www.yousendit.com/download/T2djb245OW5UME43czhUQw
    This is the link to some depth of field charts for the first released S lenses. I believe the depth of field charts are available on the Leica home site when you click on each lens and go to the specs, etc…..may be in the accompanying downloads.
