- May 20, 2014 at 7:18 am #4700
Aboud,
Had the same problem with my 30, would not focus to infinity in AF mode. It ended up back in Solms for a tuneup.Looks like your lens will get to visit the new factory in Wetzlar. Contact Kelsey Fain and maybe she can arrange a loaner for you.
-Al
- June 6, 2014 at 9:30 pm #4718
Thanks Al, I actually had an email exchange with Kelsey, but she said AF on wides can be iffy. I was giving her the benefit of the doubt until I saw your reply. My 35MM just came back from Wetzlar in March after the AF on it died completely – they had it there two months for warranty service. If they didn’t pick up on this focusing issue at infinity, I don’t think I would have much faith in them now. I’d have to send my new 30 in, that would be two lenses at once hanging out in Germany. I’d have little use of my S2 kit.
I just sent a follow up to Kelsey, we will see what happens.
– Aboud
- June 9, 2014 at 12:29 pm #4720Jack MacDEstablished Member
I have had that infinity issue with my 35 when the subject is very far and very tiny detail without a clear object to focus on. I now know to double check the setting and manually readjust. That is a function of SLRs to me. My split screen doesn’t really help either in that subject. That is the advantage of a rangefinder when using wide lenses. Net I have not chosen to send mine back for an adjustment.
Jack - June 9, 2014 at 4:51 pm #4723David FarkasNewbie
I’d add that when I use wide angle S lenses at infinity, I almost never allow the camera to auto focus focus to infinity. In my mind, doing so effectively discards a large portion of my usable DOF. I usually set the hyperfocal position manually and just shoot everything at this setting. Then, on a 30mm, I can get DOF on everything from 3ft to infinity. Why just get infinty when you could have almost the entire scene sharp?
Leica Store Miami - June 10, 2014 at 1:47 am #4724
Do you use a thumb rule for the hyperfocal distance at different apertures? It is on the M lenses but absent from the S lenses.
Bob
- June 10, 2014 at 3:17 am #4725David FarkasNewbie
bobtetreault;8390 wrote: David
Bob
Bob,
I found a good hyperfocal position with some experimentation. Generally, when shooting landscape on a tripod, I’m almost always shooting at f/11 or f/13 for maximum DOF. Any more stopped down and diffraction would start to become an issue.
Leica Store Miami - June 13, 2014 at 8:59 pm #4728
The Leica folks think that the wide angle lenses need to be calibrated to my S2-P body so everything is going to Germany next week, just as Al’s did. If it comes back focusing properly, we know it is a defect or a design flaw.
I want to preface my next statement by telling readers that I do use my S2-P on manual focus most of the time. There are times however, when I am shooting more quickly, that AF is useful. Using a hyper focal technique should not be necessary with an AF camera.
Am I the only one who thinks that a Leica $23K camera with $7K lenses should focus on infinity as my Canon bodies with wide angles do? AND if calibration is an issue, why doesn’t Leica have an AF adjustment feature like again, Canon. Finally if the AF point is an issue on the wide angle lenses, should not a sophisticated camera have a feature that adjusts the size of the focal point relative to the lens being used. How hard can that be?
Still loving’ my Leica …
Aboud
